Color Expression controls
Color Expression determines whether Corel Painter should use the main or additional color in an image. Using Color Expression, you can introduce input (such as direction) which controls output when you apply two-color brushstrokes. You can control the variation between the main and additional colors in a brushstroke by adjusting Color Jitter. You can also smooth the variation between the main and additional colors along the brushstroke.
Soft airbrush brushstrokes without Color Jitter (left) and with Color Jitter (right)
Color Jitter applied to a brushstroke without jitter smoothing (top) and with jitter smoothing (bottom)
You can also link color variation in brushstrokes to audio input from your microphone, or internal audio such as streaming music.
Brushstroke color can change in synch with audio input.
To set color expression controls
Choose
Window
Brush Control Panels
Brush Media
Color Expression.
In the
Color Expression panel, choose one of the following options from the
Expression list box:
None — applies no adjustment to the color expression
Velocity — adjusts the color expression based on the dragging speed
Direction — adjusts the color expression based on the direction of the stroke, and according to the value you set with the slider or in the box
Pressure — adjusts the color expression based on stylus pressure
Wheel — adjusts the color expression based on the wheel settings on an airbrush stylus, specifically the Wacom Intuos Airbrush stylus
Tilt — adjusts the color expression based on the angle of the stylus from the tablet
Bearing — adjusts the color expression based on the direction in which the stylus points
Rotation — adjusts the color expression based on the rotation of the stylus
Source — adjusts the color expression based on the luminance of the clone source
Random — adjusts the color expression at random
If you want to switch the main and additional colors, click the
Invert button
If you chose
Direction from the
Expression list box, move the
Direction slider until the desired angle is achieved.
To control the variation between the main and additional colors in a brushstroke
Choose
Window
Brush Media
Color Expression.
Move the
Color Jitter slider.
To smooth the color variation along the brushstroke, move the
Smoothness slider.
To link color expression to audio
Choose
Window
Brush Media
Color Expression.
Click the
Audio Expression button
To choose an audio input and adjust audio settings, choose
Window
Audio Expression
Audio Settings Panel. For more information, see
Audio Expression.
