Changing dab profiles
The Dab Profile panel displays a selection of dab profiles that you can apply to your brushes. Each brush tip profile shows a cross-section of density distribution across the diameter of the dab. You can think of a brush tip profile as a bell-curve graph representing the density spread across the brush dab.
Different media have different density distributions. Changes in the density distribution produce different marking qualities in a brushstroke. For rendered airbrush dab types, the brush tip profile controls the concentration of the spray.
Each Corel Painter brush uses one of the following brush tip profiles.
Pointed Profile
Provides maximum density at the center, with rapid falloff to the edge
Medium Profile
Has a wide area of greater density at the center, with rapid falloff to the edge
Linear Profile
Provides maximum density at the center, with even falloff to the edge
Soft Profile
Provides a strong core, with a large falloff area towards the edge
Dull Profile
Provides maximum density at the center, with high density weighting to the edge
Watercolor Profile
Provides maximum density at the outer edge in a ringlike fashion, with medium internal density. This tip may be used with the rendered dab types to yield a hollow dab or a spray concentration.
1-Pixel Edge
Provides maximum density throughout, with rapid falloff at the edge, producing a 1-pixel, anti-aliased edge
Artists’ Oils brush tip profiles
There are six brush tips designed specifically for Artists’ Oils brushes. You can also use any brush tip, listed in the table above, with Artists’ Oils brushes.
Soft Round
Pointed Rake
Provides a range of bristle lengths, with bristles longer in the center and tapering in length toward the edge
Flat Rake
Provides a range of bristle lengths and maximum density throughout, producing pronounced, even bristling
Flat
Designed for Artists’ Oils palette knives, it provides maximum density throughout, with rapid falloff at the edge
Chisel
Designed for Artists’ Oils palette knives, its maximum density is off-center, with uneven falloff
Wedge
Designed for Artists’ Oils palette knives, it provides maximum density at one edge, with consistent falloff to the other edge
Hard Media Profiles
There are seven tip profiles designed specifically for the Hard Media variants.
Pencil Profile
Provides a sharper tip when perpendicular to the tablet and a wider, softer tip when at an angle
Medium Profile
Has a wide area of greater density at the center, with rapid falloff toward the edge
Linear Profile
Provides maximum density at the center, with even falloff toward the edge
Soft Profile
Pointed Profile
Provides maximum density at the center, with rapid falloff toward the edge
Dull Profile
Provides maximum density at the center, with high-density weighting toward the edge
1-Pixel Edge
Provides maximum density throughout, with rapid falloff toward the edge, producing a 1-pixel, anti-aliased edge
To choose a brush tip profile
In the toolbox, click the
Brush tool
Click the Brush Selector on the Brush Selector bar, and choose a brush variant.
Click the
Dab Options flyout button
on the property bar.
If the selected brush is using a
Captured dab type, enable the
Apply Dab Profile check box.
4
Click a brush tip profile icon.
If your brush uses a
Circular dab type, move the
Hardness slider to adjust the opacity of the dab profile.
You can adjust the hardness only of Circular brushes that use one of the following dab profiles: Pointed, Medium, Soft, Dull, 1-pixel edge, and Watercolor.
You can also choose a dab profile by clicking Window
Brush Control Panels
Brush Shape
Dab Profile to open the Dab Profile panel, and clicking a brush tip profile icon.
