Duplicating shapes
Duplicating creates an identical copy of the selected shape. Corel Painter also lets you duplicate shapes by using compound transformations. Transformed duplicates are created according to the options you set.
To duplicate a shape
Choose the
Shape Selection tool
from the toolbox, and click a shape.
Choose
Shapes
Duplicate.
To change duplication settings
Choose
Shapes
Set Duplicate Transform.
In the
Set Duplicate Transform dialog box, specify any of the following settings:
Translation — controls where Corel Painter creates duplicate shapes in relation to the original. The offset values are in pixels. When
H. Offset and
V. Offset are both zero, the duplicate is created precisely on top of the original. If both values are 100, the duplicate appears 100 pixels lower and 100 pixels to the right. Negative values offset the duplicate up and to the left, respectively.
Scaling — controls the size of duplicates in relation to the original. The scale values are percentages.
Constrain Aspect Ratio — maintains the aspect ratio of the shape. If you want to create distorted duplicates, disable this option and specify different percentages for horizontal and vertical scaling.
Rotation — lets you specify a number of degrees to rotate duplicates. Positive values rotate counterclockwise, and negative values rotate clockwise.
Slant — controls the degree of slant applied to duplicates. Positive values slant duplicates to the right. Negative values slant them to the left. Slant accepts values between –90° and 90°. However, as values approach the extremes, the duplicate shape becomes a streak.
To create a transformed duplicate
Select the shape you want to transform.
Choose
Shapes
Duplicate.
Corel Painter creates a duplicate shape according to the specifications you’ve set.
This duplicate is now the selected shape. You can choose the
Duplicate command again, or press
Command +
] (macOS) or
Ctrl +
] (Windows), to repeat the transformation on the new shape.
The oval shape was duplicated by using rotation only (left). The number 5 shape was duplicated by using translation, scaling, and rotation (right).
