Moving, renaming, and deleting library resources
You can move a library resource to a new position within a library, or drag it to a different library. You can also rename resources, such as renaming a paper or gradient, to give them more descriptive names. You can also delete an item from a library, including a default library. You can also restore the default library to the factory settings. For information, see Restoring default libraries.
To move a library resource
In a media panel, do one of the following:
Drag a resource swatch to another position within the library.
Drag a resource swatch to another library.
If you’re dragging a swatch to a different library, you cannot position the swatch at the end of the library. You must place the swatch in between, or before, an existing swatch.
To rename a library resource
In a media panel, right-click (Windows) or Control-click (macOS) the resource that you want to rename, and choose
Rename [Resource]. (e.g.
Rename Paper)
In the
Rename dialog box, type the new name in the
Rename [Resource] text box.
To delete a library resource
In a media panel, click the resource that you want to delete.
Click the
Delete [Resource] button
Do not delete default resource files or folders.
