Editing color sets
You can customize color sets by adding, deleting, or replacing colors. You can also append colors to a color set. This is useful if you want to use colors from multiple color sets. In addition, you can name or rename individual colors in a color set.
Naming colors in a color set can be useful. You can then search for a color by name, or annotate the colors you use, right in the document window. For more information, see To find a color in a color set.
To add a color to a color set
In the
Color panel, choose a color.
In the
Color Set Libraries panel, choose the color set where you want to add the selected color.
Click the
Add Color to Color Set button
Add a sampled color to a color set
Click the Dropper tool  in the toolbox, click a color in the image, then click the Add Color to Color Set button  .
Add a color from another color set
Drag a color swatch from one color set to another.
To delete a color
In the
Color Set Libraries panel, choose a color and click the
Delete Color from Color Set button
In the warning dialog box, click
Yes.
Corel Painter deletes the chosen color from the color set.
To replace a color
Choose the color you want to add from the
Color panel, a color set, or an existing image.
Hold down
Command (macOS) or
Ctrl (Windows), and click the color you want to replace.
The new color replaces the old one in the color set.
To show or hide a color
Perform a task from the following table.
Right-click a color swatch in the Color Set Libraries panel, and choose Hide Color.
In the Color Set Libraries panel, click the Color Set options button  , choose Color Set Library View, and choose Show All Hidden Items.
To name or rename a color
Rename Color.
Type a color name in the
New name box.
Color names can contain up to 31 characters.
To restore the default color set
In the
, choose
Restore a Default Color Set.
