Importing and exporting libraries
Corel Painter lets you import and export libraries. For example, you can open a library that was created in a previous version of Corel Painter. You can also open multiple libraries at once, except in the Brush Selector. For more information, see Creating and deleting brush libraries.
All of the Corel Painter tools and media that are included in the application are stored in default libraries. For example, the default papers that are included in Corel Painter are contained in the Paper Textures libraries. When you first open a library in a media panel, the content of the default library for that given tool or media is displayed in the panel.
To import a library
Depending on the media panel, do one of the following:
Click the
Manage Libraries flyout button
, and then click
Import [Resource type] Library.
For example, if you want to open a paper textures library, click the
in the
Papers panel, and then click
Import Paper Library.
Click the
Import [Resource type] Library button
For example, if you want to open a Brush Looks library, click the
Import Look Library button
in the
Looks panel.
Choose the drive and folder where the library is stored.
The imported library displays at the bottom of the panel window. Depending on the size of the panel, you may need to scroll to see the imported library.
To import a library created in a previous version of Corel Painter
Click the
, and then click
Import Legacy [Resource type] Library.
Click the media panel’s options button
, and choose
To export a library
Click the
, and then click
Export [Resource type] Library.
For example, if you want to export a gradient library, click the
in the
Gradients panel, and then click
Export Gradient Library.
Click the
Export [Resource type] Library button
For example, if you want to export a nozzle library, click the
Export Nozzle Library button
in the
Nozzles panel.
In the
Choose Library dialog box, choose the library that you want to export from the
Library list box.
Choose the drive and folder where you want to store the library.
