Layer messages preferences
The preferences for layer messages let you set how Corel Painter behaves when you paint on the canvas, or on special layers such as Thick Paint, Watercolor, and Liquid Ink.
While many brushes are compatible with special layers, there are times when a chosen brush may produce brush marks that appear different than you would expect. There are also brushes that are simply not recommended for the current layer. In these cases, Painter will prompt you to choose how to proceed.
In addition, you can set the default behavior when painting with Gel brushes, which include Fringe Watercolor, Markers, and brush variants that use the Buildup brush method.
You can also set a default visible depth for Thick Paint layers, so that Thick Paint brushstrokes are consistent. For more information about adjusting the appearance of Thick Paint on a layer, see Adjusting Thick Paint layers.
To access the layer messages preferences
Back to Top
1 Do one of the following:
• (macOS) Choose Corel Painter 2023 menu Preferences Layer Messages.
• (Windows) Choose Edit Preferences Layer Messages.
2 Perform a task from the following table.
Description
Compatible Brushes
Lets you set a default behavior when you paint on the canvas with Fluid Paint brushes
You can choose from the following options:
• Prompt me to choose
• Allow painting on the canvas
Brushstrokes may look different than expected
• Create a new default layer
Lets you set a default behavior when you paint with compatible brushes on special layers
• Allow painting on special layers
Incompatible Brushes
Lets you set a default behavior when you paint with incompatible brushes on the current layer
• Prompt me that the brush is not compatible
• Create a new compatible layer
Gel Brushes
Fringe Watercolor, Markers, and variants that use the Buildup brush method
Lets you set a default behavior when you paint with brushes that use the Gel composite method
• Prompt me to choose a composite method
• Switch the composite method to Gel
Brushstrokes will have an ink-like, semi-transparent look.
• Maintain the Default composite method
Some brushes may produce white artifacts.
Merging Special, Plug-in, and Shape Layers
Lets you set a default behavior when converting special, plugin, and shape layers to a default layer
