Mouse controls
In theory, a mouse has no pressure information. A mouse button is either on (button down), or off (button up). However, the Corel Painter Mouse controls let you simulate the following stylus settings:
Pressure (how hard you would be pressing with a stylus)
Tilt (how close to vertical the stylus is held)
Bearing (the compass direction in which the stylus is pointing)
Rotation (to simulate using a flat-tip stylus that supports 360-degree rotation)
Wheel (how much ink is sprayed).
For more information, see Using a stylus vs. a mouse.
You can record and save brushstrokes created with a stylus and then have Corel Painter use the saved settings for the stroke when you switch to a mouse. For more information about using saved brushstrokes to further enhance mouse functionality, see Recording and playing back brushstrokes.
To set pressure for the mouse
Choose
Window
Brush Control Panels
Mouse.
Move the
Pressure slider.
A 100% setting uses maximum pressure.
To set tilt for the mouse
Choose
Window
Mouse.
A 90º setting indicates that if a stylus were in use, it would be perpendicular to the tablet.
To set bearing for the mouse
Choose
Window
Mouse.
Move the
Bearing slider.
A setting of
0º indicates that if a stylus were in use, it would be pointing left.
To set rotation for the mouse
Choose
Window
Mouse.
Move the
Rotation slider.
A 360° setting simulates a stylus that completes a 360° barrel rotation.
Rotation is supported only when you are using a brush with the Expression setting set to Rotation. For more information, see Expression settings.
To set ink flow for the mouse
Choose
Window
Mouse.
A setting of 100% indicates that maximum flow is in effect.
