Scaling and rotating selections
You can scale or rotate selections. Scaling lets you change the dimensions of a selection. You can also scale an object proportionally by preserving its aspect ratio.
To scale a selection
In the toolbox, click the
Transform tool
If the
Transform tool is not displayed in the toolbox, click and hold the
Layer Adjuster tool
to open the flyout, then select the
Transform tool
On the property bar, click the
Scale button
Perform a task from the following table.
Scale a selection in one dimension
Drag a side, top, or bottom handle. On the property bar, click the Commit Transformation button  .
Scale a selection in two dimensions
Drag a corner handle. On the property bar, click the Commit Transformation button  .
Scale while maintaining the selection’s shape, or "aspect ratio"
Hold down Shift while you drag a corner handle. On the property bar, click the Commit Transformation button  .
Scale around the reference point while maintaining the selection’s shape, or "aspect ratio"
Hold down Alt + Shift (Windows) or Option + Shift (macOS), and drag a corner handle. On the property bar, click the Commit Transformation button  .
Hold down Alt (Windows) or Option (macOS), and drag a corner handle. On the property bar, click the Commit Transformation button  .
Drag a side handle to scale horizontally.
You can also scale a selection by choosing Edit
Transform
Scale, and specifying the horizontal and vertical scale percentages in the dialog box.
To rotate a selection
Transform tool
If the
Layer Adjuster tool
to open the flyout, and then choose the
Transform tool
Rotate button
Move the pointer outside the border of the selection’s bounding box.
If you want to constrain the rotation by 15-degree increments, hold down
Shift while dragging.
5
You can also Rotate a selection by choosing Edit
Transform
Rotate, and specifying the rotation angle in degrees in the dialog box. A positive number rotates clockwise; a negative number rotates counterclockwise.
Rotating a selection
