Storing layers as images in the Image Portfolio
The Image Portfolio is a convenient place to store layers as images so you can use them again.
You can create your own Image Portfolio libraries to organize images by category. When you’re creating a library, keep in mind that the smaller the library, the easier it will be to see its contents at a glance.
You can also move items between Image Portfolio libraries. For more information, see Working with libraries.
To display the Image Portfolio panel
Back to Top
Choose Window Media Panels Images.
If the Image Portfolio panel is not expanded, double-click the Image Portfolio panel tab.
To add a layer to the Image Portfolio
Back to Top
1 Select a layer.
2 In the toolbox, click the Layer Adjuster tool .
3 In the Image Portfolio panel, click the Image Portfolio options button , and choose Add Image To Portfolio.
The layer is added to the portfolio.
4 In the Save Image dialog box, type a name in the Save As box.
The Image Portfolio holds only pixel-based layers. If you want to add a shape, Watercolor, Liquid Ink, or dynamic layer to the Image Portfolio, you must first convert it to a default layer. In the Layers panel, right-click the layer, and choose Convert To Default Layer.
To use an image from the Image Portfolio
Back to Top
1 Choose Window Media Panels Images.
2 Double-click an item in the Image Portfolio panel to add it to the document window.
Corel Painter places the Image Portfolio item on a new layer.
