Working with reference layers
Reference layers get their image content from an external source — either a pixel-based layer in the current document or a separate file. They provide a low-resolution representation of the original image that you can quickly manipulate in ways that would otherwise require more time. Working with a reference layer allows you to resize, rotate, or slant a layer onscreen by dragging its handles. The changes are immediately displayed in the document window. When you finish making changes, you can commit the reference layer back to a standard layer. Corel Painter examines the source image to restore the original resolution.
You cannot edit the image data in a reference layer. If you try to paint on or apply effects to a reference layer, Corel Painter prompts you to commit it back to a pixel-based layer.
You can create a reference layer by basing it on an existing layer or by placing an image. For more information, see Opening files.
To create a reference layer
Back to Top
1 Select a layer.
2 Click the Layer options button in the Layers panel, and choose Convert To Reference Layer.
The layer’s icon in the Layers panel changes to an eight-handled shape , and an eight-handled box marks the boundary of the layer’s contents in the document window.
You can also create a reference layer by right-clicking a layer in the Layers panel, and choosing Convert To Reference Layer.
You can also create a reference layer by selecting the layer, and choosing Layers Convert To Reference Layer.
To modify a reference layer
Back to Top
• Select a reference layer.
To
Do the following
Resize a reference layer in one direction
Drag a side handle.
Resize a reference layer in more than one direction at once
Drag a corner handle. If you want to maintain the layer proportions, hold down Shift as you drag. The pointer changes when you position it over a corner handle .
Rotate a reference layer
Hold down Command (macOS) or Ctrl (Windows), and drag a corner handle. The pointer changes when you position it over a corner handle .
Skew a reference layer
Hold down Command (macOS) or Ctrl (Windows), and drag a side handle. The pointer changes when you position it over a side handle .
To commit a reference layer
Back to Top
• In the Layers panel, right-click a reference layer, and click Convert To Default Layer.
The conversion process might take a few seconds, depending on the size and quality of the layer.
