• | To apply a color fill |
• | To apply a pixel-based color fill |
Feathering softens the edges of the fill by controlling the fill opacity for pixels with colors outside the tolerance range. For example, if feather is set to zero (the default), only pixels in the tolerance range are filled. With a low feather setting, pixels with colors just outside the Tolerance range receive partial fill. Increasing the feather setting increases the range of colors that receive partial fill. Pixels with colors farther from the tolerance range receive a more transparent fill. Typically, when feather is set high, tolerance is set low.
1 . | In the Color panel, double-click the Main Color (front) swatch ![]() |
2 . | Choose a color from the Color dialog box. |
3 . | To apply a gradient to: |
• | The canvas — Click the Canvas in the Layers panel. |
• | A selection — Click a selection tool from the toolbox, and drag in the document window to select an area. |
• | A layer — Click a layer in the Layers panel. |
• | A channel — Click a channel in the Channels panel. |
4 . | Choose Edit ![]() |
If you prefer, press Command + F (macOS) or Ctrl + F (Windows). |
5 . | In the Fill dialog box, choose Current Color from the Fill with list box. |
6 . | Adjust the Opacity slider. |
1 . | Choose Window ![]() ![]() |
2 . | In the Color Sets panel, click the Color Sets options button |
3 . | In the New Colorset dialog box, type a name in the Name text box. |
4 . | Choose the Paint Bucket tool |
5 . | On the property bar, click one of the following buttons: |
• | Fill Image |
• | Fill Cell |
6 . | Choose the Current Color option from the Fill list box. |
7 . | Open the Select Fill panel, and choose a color. |
The image color set displays in the Select Fill palette. |
8 . | Click the image in the drawing window. |
If the result is not what you want, undo the fill, change the settings, and try again. |
On the property bar, type a value in the Tolerance box or adjust the slider.
On the property bar, type a value in the Feather box or adjust the slider.
On the property bar, click the Anti-Alias button
Anti-aliasing is desirable when the Feather setting is set to zero or extremely low.
You can constrain the fill to a rectangular area by dragging with the Paint Bucket tool.
