You can organize your content by using trays or by adding content files to specific folders on your computer.
A tray is useful for gathering content from various folders. While the files are referenced in the tray, they actually remain in their original location. You can add and remove content from the tray. The tray is shared between CorelDRAW, Corel PHOTO-PAINT, and Corel CONNECT. You can also open files from the tray to preview them more easily.
You can create trays so that you can organize your content. Trays are saved to your user folder with .Tray file extensions. You can change the default folder to which trays are saved. For example, you can save a tray to a network folder to share it with others.
You can rename trays to give them meaningful names. When working with multiple trays, you can close some trays temporarily to avoid clutter. You can easily reopen a tray when you need it. In addition, you can load a tray file that is not listed among the available trays. You can delete a tray at any time.
| To add content to a tray |
Select one or more thumbnails in the viewing pane, and drag them to the tray.
If you want to open a file from the tray, double-click its thumbnail. |
You can also drag content from a folder on your computer to the tray.
| To add content to a folder |
Select one or more thumbnails in the viewing area, and drag them to a folder in the
Favorite Folders or Folders pane, or any other folder on your computer.
You can drag content from the tray to a folder.
| To remove content from a tray |
Select one or more thumbnails in the tray, and click the Remove from tray button
| To create a tray |
Click the Add new tray button |
By default, a tray is saved to the Users\[UserName]\My Documents\Corel\Corel Content\Trays folder. |
You can e-mail trays that contain only online content.
| To change the folder to which trays are saved |
1. |
Click the arrow on the Help and options button, and click Options.
2. |
Type a path in the Default tray location box.
To browse to a folder, click the Browse button next to the Default tray
location box.
To share a tray, you can save it to a network folder.
| To work with trays |
You can also close and delete a selected tray from the All trays menu.
