Syncing trays with SkyDrive
Premium feature
In Corel CONNECT, you can sync your trays with SkyDrive and have access to your content from other computers or mobile devices. You must have a SkyDrive account to use this feature. After you sign in, you can see all your SkyDrive folders in the Libraries pane in Corel CONNECT and view their content in the viewing pane.
When you delete files from the trays, the files are also deleted from SkyDrive when the trays are synced.
After you sign in, your SkyDrive folders appear in the Libraries pane.
Trays are stored in Users\[UserName]\Documents\Corel\Corel Content\Trays. Each tray is stored as a separate folder. If the trays have never been synced with SkyDrive, each tray folder contains shortcuts to the files that have been added to the tray, while the actual files remain in their original location. However, when you sync the trays with SkyDrive, all files added to the trays are copied from their original location to the respective tray folder.
When you sync trays with SkyDrive, the synced files appear in the following SkyDrive folder: SkyDrive\Apps\Corel\Trays.
For more information about Corel CONNECT, see Finding and managing content.
To sync trays with SkyDrive Back to Top
1.
In Corel CONNECT or the Connect docker, click SkyDrive in the Libraries pane.
2.
Sign in when prompted.
The first time you sign in, you are asked to grant Corel Cloud Service access to your account. You can always change this setting by logging into SkyDrive online and specifying which applications have access to your account.
3.
When asked whether you want to enable Tray Sync, click Yes.
4.
Make sure that the Enable Tray Sync with SkyDrive on this computer check box is enabled, and choose an option from the Sync frequency list box.
Your SkyDrive folders and content appear in the viewing pane.
You can also
Upload files to SkyDrive
Drag the files from the viewing pane or from the desktop to a SkyDrive folder.
You can also drag files to a tray. If the trays are synced, the files in the tray are automatically uploaded to SkyDrive.
Import files from SkyDrive into your document
Select the file in the viewing pane, and click the Import button , or drag the file to an open CorelDRAW or Corel PHOTO-PAINT document.
Remove files from a synced SkyDrive folder
Select the file in the tray, and click the Remove from tray button .
When the tray is synced, the file is removed from the synced location in SkyDrive.
If you delete a file from a synced SkyDrive folder, the file from the local tray folder is moved to the Recycle Bin when the trays are synced.
Access SkyDrive online
In the viewing pane, right-click a SkyDrive file or folder, and choose Open source location from the context menu.
SkyDrive opens in a browser, where you can manage your SkyDrive files and folders.
Sign out of SkyDrive
In the Libraries pane, click the Configure content libraries button , and click Sign out in the SkyDrive area.
If trays are syncing and there is a conflict between two files with the same name, both files are kept, and a number is appended to the name of the second file.
If you do not enable Tray Sync, you can still see your SkyDrive folders in Corel CONNECT and upload or download files.
The tray tab icons indicate the sync status of the tray: offline , error , syncing , or synced .
