Image Adjustment Lab
The Image Adjustment Lab lets you correct the color and tone of most photos quickly and easily.
The Image Adjustment Lab consists of automatic and manual controls, which are organized in a logical order for image correction. By starting in the upper-right corner and working your way down, you can select only the controls you need to correct the problems specific to your image. It is best to crop or retouch any areas of the image before beginning the color and tone corrections.
When you work in the Image Adjustment Lab, you can take advantage of the following features:
Create snapshot — You can capture the corrected version of an image in a "snapshot" at any time. Thumbnails of the snapshots appear in a window below the image. Snapshots make it easy to compare different corrected versions of the image so you can choose the best one.
Undo,
Redo, and
Reset — Image correction can be a trial-and-error process, so the ability to undo and redo corrections is important. The
Reset command lets you clear all corrections so that you can start again.
Remember settings — Enabled by default, this check box lets you use the current settings on other images. Disable the check box if you want to restore the default settings each time you open an image in the Image Adjustment Lab.
Using automatic controls
You can begin by using the automatic correction controls:
Auto adjust — automatically corrects the
contrast and color in an image by detecting the lightest and darkest areas and adjusting the
tonal range for each color channel. In some cases, this control may be all you need to improve an image. In other cases, you can undo the changes and proceed with more precise controls.
Select white point tool — automatically adjusts the contrast in an image according to the white point that you set. For example, you can brighten an image that is too dark by using the
Select white point tool.
Select black point tool — automatically adjusts the contrast in an image according to the black point that you set. For example, you can darken an image that is too light by using the
Select black point tool.
Using color correction controls
After using the automatic controls, you can correct color casts in your image. Color casts are typically caused by the lighting conditions when a photo is taken, and they can be influenced by the processor in your digital camera or scanner.
Temperature slider — lets you correct color casts by "warming" or "cooling" the color in an image to compensate for the lighting conditions at the time the photo was taken. For example, to correct a yellow color cast caused by taking a photo indoors in dim incandescent lighting, you can move the slider toward the blue end to increase the temperature values (based on degrees Kelvin). Lower values correspond to low lighting conditions, such as candlelight or light from an incandescent light bulb; these conditions cause an orange cast. Higher values correspond to intense lighting conditions, such as sunlight; these conditions cause a blue cast.
Tint slider — lets you correct color casts by adjusting the green or magenta in an image. You can add green by moving the slider to the right; you can add magenta by moving the slider to the left. Moving the
Tint slider after using the
Temperature slider lets you fine-tune an image.
Saturation slider — lets you adjust the vividness of colors. For example, by moving the slider to the right, you can increase the vividness of a blue sky in an image. By moving the slider to the left, you can reduce the vividness of colors. You can create a black-and-white photo effect by moving the slider all the way to the left, so that all color in the image is removed.
Correction of a color cast. The image on the right is the corrected version.
Adjusting brightness and contrast across an entire image
You can brighten, darken, or improve the contrast in an entire image by using the following controls:
Brightness slider — lets you brighten or darken an entire image. This control can correct exposure problems caused by too much light (overexposure) or too little light (underexposure) at the time the photo was taken. If you want to lighten or darken specific areas of an image, you can use the
Highlights,
Shadows, and
Midtones sliders. Adjustment made by the
Brightness slider is nonlinear, so the current white point and black point values are not affected.
Contrast slider — increases or decreases the difference in tone between the dark and light areas of an image. Moving the slider to the right makes the light areas lighter and the dark areas darker. For example, if the image has a dull, gray tone, you can sharpen the detail by increasing the contrast.
Adjusting the brightness and contrast of an image can reveal more image detail.
Adjusting highlights, shadows, and midtones
You can brighten or darken specific areas of an image. In many cases, the position or strength of the lighting at the time a photo is taken causes some areas to appear too dark and other areas to appear too light.
Highlights slider — lets you adjust brightness in the lightest areas of an image. For example, if you take a photo with a flash, and the flash washes out the foreground subjects, you can move the
Highlights slider to the left to darken the washed-out areas of the image. You can use the
Highlights slider in conjunction with the
Shadows and
Midtones sliders to balance the lighting.
Shadows slider — lets you adjust the brightness in the darkest areas of an image. For example, a bright light behind a photo subject (backlighting) at the time a photo is taken can cause the subject to appear in shadow. You can correct the photo by moving the
Shadow slider to the right to lighten the dark areas and reveal more detail. You can use the
Shadows slider in conjunction with the
Highlights and
Midtones slider — lets you adjust the brightness of the midrange tones in an image. After adjusting the highlights and shadows, you can use the
Midtones slider to fine-tune the image.
The Highlights and Shadows sliders can lighten or darken specific areas of an image.
Using the histogram
The histogram lets you view the tonal range of an image to evaluate and adjust the color and tone. For example, a histogram can help you detect hidden detail in a photo that is too dark because of underexposure (a photo taken with insufficient light).
The histogram plots the brightness values of the pixels in an image on a scale of 0 (dark) to 255 (light). The left part of the histogram represents the shadows, the middle part represents the midtones, and the right part represents the highlights. The height of the spikes indicates how many pixels are at each brightness level. For example, a higher number of pixels on the left side of the histogram indicates the presence of image detail in the dark areas of the image.
The photo on the left is underexposed. Right: The histogram indicates a large amount of image detail in the dark areas of the photo.
Viewing images in the Image Adjustment Lab
The tools in the Image Adjustment Lab let you view images in various ways, so that you can evaluate the color and tone adjustments you make. For example, you can rotate images, pan to a new area, zoom in or out, and choose how to display the corrected image in the preview window.
Using other adjustment filters
Although the Image Adjustment Lab lets you correct the color and tone of most images, a specialized adjustment filter is sometimes required. Using the powerful adjustment filters in the application, you can make precise adjustments to images. For example, you can adjust images by using a tone curve. For more information about adjustment filters, see Adjust color and tone.
To correct color and tone in the Image Adjustment Lab
Click
Effects
Adjust
If you want to control the white point and black point setting more precisely, click the
![](../Shared_graphics/set-white-point.svg)
, and click the lightest area of your image. Then click the
![](../Shared_graphics/set-black-point.svg)
, and click the darkest area of your image.
Perform one or more tasks from the following table.
Correct color in the image
Adjust the Temperature slider to warm or cool the colors, and then fine-tune the color correction by adjusting the Tint slider.
Make colors more vivid or less vivid
Move the Saturation slider to the right to increase the amount of color in the image; move the slider to the left to decrease the amount of color in the image.
Brighten or darken an image
Move the Brightness slider to the right to lighten the image; move the slider to the left to darken the image.
Improve image sharpness by adjusting tone
Move the Contrast slider to the right to make the light areas lighter and the dark areas darker.
Brighten or darken specific areas
Move the Highlights slider to brighten or darken the lightest areas of the image. Then, move the Shadows slider to lighten or darken the darkest areas of the image. Finally, move the Midtones slider to fine-tune the midrange tones in the image.
![*](images/note.svg)
The Image Adjustment Lab is not available for CMYK images. For CMYK images, you can access the Auto adjust filter and other adjustment filters from the Effects menu.
![*](images/tip.svg)
You can capture the current version of your image by clicking the Create snapshot button. Thumbnails of the snapshots appear in a window below your image. Each snapshot is numbered sequentially and can be deleted by clicking the Close button in the upper-right corner of the snapshot title bar.
You can undo or redo the last correction you made by clicking the Undo button
or the Redo button
. To undo all corrections, click the Reset to original button.
To view images in the Image Adjustment Lab
Click
Effects
Adjust
Perform a task from the following table.
Click the Rotate left button ![](../Shared_graphics/rotate-counter-clockwise.svg) or the Rotate right button ![](../Shared_graphics/rotate-clockwise.svg) .
Pan to another area of an image
Using the Pan tool ![](../Shared_graphics/pan.svg) , drag the image until the area you want to see is visible.
Using the Zoom in tool ![](../Shared_graphics/zoom-in.svg) or the Zoom out tool ![](../Shared_graphics/zoom-out.svg) , click in the preview window.
Fit an image in the preview window
Click the Zoom to fit ![](../Shared_graphics/zoom-to-fit.svg) button.
Display an image at its actual size
Click the 100% ![](../Shared_graphics/zoom-to-100.svg) button.
View the corrected image in a single preview window
Click the Full preview button ![](../Shared_graphics/full-preview.svg) .
View the corrected image in one window and the original image in another window
Click the Before and after full preview button ![](../Shared_graphics/2-vert-panes-preview.svg) .
View the image in one window with a divider between the original and corrected versions
Click the Before and after split preview button ![](../Shared_graphics/before-split-preview.svg) . Move your pointer over the dashed divider line, and drag to move the divider to another area of the image.
