The Adobe Illustrator (AI) file format was developed by Adobe Systems, Incorporated for the Macintosh and Windows platforms. It is primarily vector-based, although later versions support bitmap information.
You can import AI files for use in CorelDRAW or export CorelDRAW files to the AI file format. Before exporting a document as an AI file, you can preflight your document to find potential problems. Preflighting checks and displays a summary of errors, possible problems, and suggestions for resolving issues. By default, many AI issues are checked during a preflight, but you can disable the issues that you do not want to check.
To import an Adobe Illustrator file | ![]() |
1 |
Click File ![]() |
2 |
Locate the folder in which the file is stored.
3 |
Do one of the following:
(Windows 7 and Windows Vista) Choose AI - Adobe Illustrator from the list
box next to the File name box.
(Windows XP) Choose AI - Adobe Illustrator from the Files of type list box.
4 |
Click the filename.
5 |
Click Import.
6 |
Click in the drawing page where you want to import the file.
To export an Adobe Illustrator file | ![]() |
1 |
Click File ![]() |
2 |
Locate the folder in which you want to save the file.
3 |
Choose AI - Adobe Illustrator from the Save as type list box.
4 |
Type a filename in the File name list box.
5 |
Click Export.
6 |
From the Compatibility list box, choose an Adobe Illustrator file format.
7 |
In the Export range area, enable one of the following options:
Current document — exports the active drawing
Current page — exports the active page
Selection — exports the objects that you have selected
Pages — exports the pages that you specify (This option is only available for CS
4.)
8 |
In the Export text as area, enable one of the following options:
Curves — lets you export text as curves
Text — lets you export text as editable characters
If you enable the Simulate complex filled curves check box, an object that is
composed of complex curves, such as a text object that was converted to curves,
may be broken into several objects on export to help minimize the complexity
of the object.
If you disable the Include placed images check box and export the file, the
exporting process generates one Adobe Illustrator file and a series of EPS files.
The EPS files contain individual objects and images which are linked to the AI
file. Always store the EPS files with the AI file to preserve the link to the AI file.
To view the preflight summary for an AI file | ![]() |
1 |
Click File ![]() |
2 |
3 |
4 |
5 |
Click Export.
6 |
In the Adobe Illustrator Export dialog box, click the second tab.
You can limit the issues to check during the preflight by clicking the Settings button, double-clicking AI Export, and disabling the check boxes next to the items that you want the preflight to overlook. |
You can save settings by clicking the Add preflight settings button and
typing a name in the Save preflight style as box.
Adobe Illustrator (AI) technical notes | ![]() |
Corel programs provide full support for all AI file formats up to and including
Adobe Illustrator CS4.
For files saved in Adobe Illustrator CS or higher with PDF-compatibility, text can
be imported as text or curves.
Corel programs cannot import AI files containing bitmaps linked as EPS files.
Adobe Illustrator graphics are imported into the program as a group of objects.
Click Arrange ![]() |
Flash movies embedded in AI files are not imported.
For AI CS4 files, each Artboard is imported as an individual CorelDRAW page. In
multi-page documents, objects that are placed off of a page are placed on the first
page of the CorelDRAW document.
Objects filled by using Live Color groups (color schemes) appear correctly in
CorelDRAW, but the Live Color groups are not maintained as color styles.
Certain compression settings in Adobe Illustrator may further compress the file to
save space, making it difficult to open the file in CorelDRAW. To avoid this
problem, open the file in Adobe Illustrator and change the document settings so
that the file is not compressed.
During export conversion, objects can become complex, making it difficult to edit
them in other drawing programs or in CorelDRAW if you reimport them. To avoid
this problem, save the file to the CorelDRAW (CDR) format before exporting it,
and use CorelDRAW for all editing.
If you create a file that will be printed in other programs, such as Adobe
PageMaker, export it using the Encapsulated PostScript (EPS) filter, not the Adobe
Illustrator (AI) filter. The Encapsulated PostScript filter supports more drawing
effects than the Adobe Illustrator filter does and yields better results overall.
Most linear and radial fountain fills are preserved. Conical and square fountain fills
are exported as a series of filled bands, an effect similar to that achieved by
blending. You can set the number of bands by clicking Tools ![]() |
To accurately reproduce calligraphic outlines, corner styles, and line caps, click
Tools ![]() |
You can export text as text when you are exporting AI files from versions CS and
later.
When exporting multi-page CorelDRAW files to the CS4 format, individual pages
are exported as Artboards. They are also layed out using the Arrange by row
format.
When exporting multi-page CorelDRAW files to the CS4 format, objects that are
placed off of the page are removed.
