You can apply PostScript texture fills to objects. A PostScript texture fill is created in the PostScript language. Some textures are very complex, and large objects that contain PostScript texture fills may take time to print or to update on the screen. Depending on the view mode you are using, the letters “PS” — rather than the fill — may appear. For more information about displaying PostScript fills, see Working with views.
When you apply a PostScript texture fill, you can change several parameters, such as the size, line width, and the amount of gray that appears in the texture's foreground and background.
| To apply a PostScript texture fill |
1 |
Select an object.
2 |
In the toolbox, click the Interactive fill tool |
3 |
Choose PostScript fill from the Fill type list box on the property bar.
4 |
Choose a PostScript fill from the PostScript fill textures list box.
If you want to change the fill's parameters, click the Edit fill button |
