After creating all the data fields you want for a drawing, you can create a database. The Object data docker and the Object Data Manager provide all the commands and features you need to add and edit object information.
The Object data docker is best for entering data for single objects. It lets you add, edit, and delete object data.The Object Data Manager, in contrast, is best for entering and editing data for multiple objects. It provides many of the editing features available in popular spreadsheet applications.
You can use one object’s data entries to update another object’s data entries. This function does not replace an object’s data entries; rather, it appends fields and data where appropriate.
| To add or edit data for an object |
1 |
Select the object using the Pick tool |
2 |
Click Tools |
3 |
Select a data field. Type text in the Value column for the field, and press Enter.
4 |
Repeat step 3 to add data to other fields.
You can also
Clear one field
Click the Clear field button
Clear all fields
Click the Clear all fields button
| To add or edit data for multiple objects |
1 |
Select the objects using the Pick tool |
2 |
Click Tools |
3 |
In the Object data docker, click the Open spreadsheet button |
4 |
In the Object Data Manager window, click a cell, and type the appropriate data.
Press Enter to assign the entry to the cell, the fields, and the objects.
| To copy data from one object to another |
1 |
Using the Pick tool |
2 |
Click Tools |
3 |
In the Object data docker, click the Copy data from button |
4 |
Click the object from which you want to copy data.
