You can enhance both artistic text and paragraph text by modifying the character properties. You can also change the default text style, so that the same properties are applied to all new artistic or paragraph text. For example, you can change the font type and size, or change the text to bold or italic.
You can change the text format to subscript or superscript, which is useful if a drawing contains scientific notation. You can also add underlines, strikethrough lines, and overlines to text. In addition, you can change the thickness of these lines and change the distance between the lines and the text. For information about previewing fonts, see Previewing and identifying fonts.
You can change text to lowercase or uppercase without deleting or replacing letters. You can also increase or decrease font size by a specified increment. By default, the unit of measure is points. You can change this setting for the active drawing and all subsequent drawings that you create, so that the new unit of measure is used in all font settings.
If you need to increase the redraw speed for text that is smaller than a specific font size, you can use lines to represent the text. This method, called “greeking” text, is useful for creating prototypes of documents or drawings. You can make text readable again by reducing the greeking value or by zooming in on the text.
| To change the default text style |
1 |
Using the Pick tool |
2 |
In the Character formatting docker, change any of the text properties.
If the Character formatting docker does not appear in your workspace, click Text |
By default, you must specify whether to apply each modified text property to artistic text, to paragraph text, or to both. |
To use the modified text style as the default for future documents, click Tools
To make the style of an existing text frame or object the default style, click
Window |
| To change character properties |
1 |
Select the text.
2 |
In the Character formatting docker, perform one or more tasks from the
following table.
You can also change the font and font size from the property bar.
You can also change the formatting of selected text by clicking the Bold
button |
| To change the text color |
1 |
Using the Text tool |
2 |
Click a color on the color palette.
You can change the color of an entire text object by selecting it with the Pick
tool |
| To change the text case |
1 |
Select the text.
2 |
Click Text |
3 |
Enable one of the following options:
Sentence case — capitalizes the initial letter of the first word in each sentence
Lowercase — makes all text lowercase
Uppercase — makes all text uppercase
Title case — capitalizes the initial letter of each word
Toggle case — changes all uppercase letters to lowercase, and all lowercase
letters to uppercase
| To resize text |
| To greek text |
1 |
Click Tools |
2 |
In the list of categories, click Workspace |
3 |
Type a value in the Greek text below box.
