EPS files are PostScript files that are embedded in a document. You can choose how encapsulated PostScript (EPS) files are viewed in a PDF document. The PostScript option includes high-resolution images in the PDF document but does not let you view them in Adobe Acrobat. The Preview option includes high-resolution images in the PDF file and displays their low-resolution bitmap representation in Adobe Acrobat.
To choose a viewing option for EPS files | ![]() |
1 |
Click File ![]() |
2 |
Choose PDF - Adobe Portable Document Format from the Save as type list
box.
3 |
Locate the folder in which you want to save the file.
4 |
Type a filename in the File name box.
5 |
Click Export.
The PDF settings dialog box appears. |
6 |
Click the Objects tab.
7 |
Choose one of the following from the EPS files list box:
PostScript — includes high-resolution images in the PDF document but does
Preview — includes high-resolution images in the PDF file and displays their
