Files saved to the Corel PHOTO-PAINT (CPT) file format are bitmaps that represent shapes as pixels arranged to form an image. When you save a graphic to the Corel PHOTO-PAINT format, masks, floating objects, and lenses are saved with the image. CorelDRAW can import and export files in Corel PHOTO-PAINT format, including files that contain color and grayscale information.
To export a Corel PHOTO-PAINT file | ![]() |
1 |
Click File ![]() |
2 |
Locate the folder in which you want to save the file.
3 |
Choose CPT - Corel PHOTO-PAINT image from the Save as type list box.
4 |
Type a filename in the File name list box.
5 |
Click Export.
6 |
In the Convert to bitmap dialog box, adjust the width, height, resolution, color
mode, or any of the other settings.
You can export CorelDRAW layers as objects in the CPT file format.
You can export to an image with transparent background.
Corel PHOTO-PAINT (CPT) technical notes | ![]() |
This filter is available in CorelDRAW, Corel PHOTO-PAINT, and
Corel DESIGNER.
