You can edit a template by making changes to the styles, page layout settings, or objects. For example, if you like a template but want to make it more versatile, you can add styles that you’ve created or that you’ve taken from another template. For information about setting page layout options, see Specifying the page layout.
| To edit a template |
1 |
Click File |
If you are using Windows XP, choose CDT - CorelDRAW template from the Files of type list box. |
2 |
Locate the folder where the template is stored.
If you are using Windows XP, you can preview the contents of a template by enabling the Preview check box. |
3 |
Double-click a template filename.
4 |
In the Open dialog box, enable the Open for editing check box.
