You can embed a graphic object or bitmap in text. The graphic object or bitmap is treated as a text character. As a result, you can apply formatting options according to the type of text in which you embed the graphic object. You can also remove an embedded object from text, after which the object returns to its original state.
You can add special characters to text as text objects or as graphic objects. When you add special characters as text, you can format the characters as you do the text. When you add special characters as graphic objects, the characters are curves. Consequently, you can edit them as you would other graphic objects.
| To embed a graphic object in text |
1 |
Select a graphic object.
2 |
Click Edit, and click one of the following:
Cut
Copy
3 |
Using the Text tool |
4 |
Click Edit |
| To remove an embedded object from text |
1 |
2 |
Click Edit |
3 |
Click the Pick tool |
4 |
Click Edit |
| To add a special character as a text object |
1 |
2 |
Click Text |
3 |
In the Insert character docker, choose a font from the Font list box.
4 |
Double-click a character in the list.
The size of the character is determined by the font size of the text. |
The Insert character docker displays the keyboard shortcuts that you can use
to add special characters.
| To add a special character as a graphic object |
1 |
Click Text |
2 |
3 |
Type a value in the Character size box.
4 |
Drag a special character from the list to the drawing page.
The special character is inserted with the default graphic style. For information
about graphic styles, see Working with graphics, text, and color styles.
