You can fine-tune print jobs before to ensure printing quality. Because problems sometimes occur when you are printing text to a non-PostScript printing device (GDI printer), you can decrease printing time by specifying driver compatibility for non-PostScript printing devices. For more information, see Printing colors accurately.
If a printing device has difficulty processing large bitmaps, you can divide a bitmap into smaller, more manageable chunks by setting an output threshold. If any lines appear when the printing device prints the chunks, you can set an overlap value to produce a seamless image.
On occasion, you may experience difficulties with printing complex files. To print complex files, you may need to spend a considerable amount of time fixing and correcting the files. Another option is to convert a page to a bitmap, which is also known as rasterizing, which can allow you to print complex files.
To reduce file size, you can downsample bitmaps. Because bitmaps are made up of pixels, when you downsample a bitmap, the number of pixels per line decreases, which decreases the file size.
| To specify driver compatibility settings |
1 |
Click Tools |
2 |
In the list of categories, double-click Global, Printing, and click Driver
compatibility.
3 |
Choose a non-PostScript printing device from the Printer list box.
4 |
Enable any of the check boxes that correspond to the settings that you want to
specify.
| To choose a threshold and chunk overlap |
1 |
Click Tools |
2 |
In the list of categories, double-click Global, and click Printing.
3 |
From the Option list, choose one of the following:
Bitmap output threshold (K)
Bitmap chunk overlap pixels
4 |
Choose a value from the Setting list box.
| To print as a bitmap |
1 |
Click File |
2 |
On the General tab, enable the Print as bitmap check box, and type a number in
the dpi box to set the resolution.
| To downsample bitmaps |
1 |
Click File |
2 |
Click the Prepress tab.
3 |
In the Bitmap downsampling area, enable any of the following check boxes and
type a value in the corresponding box:
Color and Grayscale
Monochrome
Downsampling bitmaps affects them only when their resolution is higher than
the resolution specified in the Bitmap downsampling area.
