Lines are treated the same way as outlines of closed shapes, such as ellipses and polygons. You can change the appearance of both lines and outlines by using the controls of the Outline pen dialog box, the Outline page of the Object properties docker, and the property bar. For example, you can specify the color, width, and style of lines and outlines.
You can choose a corner style to control the corner shape in lines and choose a line cap style to change the appearance of a line’s endpoints. By default, an outline is applied on top of an object’s fill, but you can apply it behind the fill, with the fill overlapping the outline. You can also link the outline thickness to an object’s size so that the outline increases when you increase the object’s size and decreases when you decrease the object’s size.
Different corner styles were applied to the upper and lower row of triangles. Different line caps were applied to the lines in the upper-right corner. Arrowheads were applied to the lines in the lower-right corner.
When an object contains lines that meet at sharp angles, you can set the miter limit to determine their corner shape. Corners with angles above the miter limit are pointed (mitered); corners with angles below the miter limit are beveled (squared off).
You can create calligraphic outlines. A calligraphic outline varies in thickness, creating the effect of a hand-made drawing. In addition, you can add arrowheads to lines and curves. You can create new arrowheads and edit existing arrowheads.
The default line and outline properties for each new object that you draw are as follows:
hairline width
CMYK black color
solid line
square corner and line cap styles
no arrowheads applied
outline applied on top of an object’s fill
outline not linked to an object’s size. However, you can change any of these default
line and outline properties at any time.
In some programs, outlines are known as strokes or thick lines.
To create a cuttable outline for devices such as plotters and vinyl cutters, which cannot interpret outline width; you need first to convert the outline to an object. For more information, see To add an arrowhead.
Another way to create a cuttable outline is by using a contour effect. For more information, see To contour an object.
| To specify line and outline settings |
1 |
Select an object.
2 |
In the toolbox, click the Outline tool |
3 |
Open the color picker, and click a color.
4 |
Type a value in the Width box.
5 |
Choose a line style from the Style box.
You can quickly access the Outline pen dialog box by double-clicking the
Outline icon on the status bar.
You can also change the outline width of a selected object by typing a value in
the Outline width box on the property bar.
| To create a calligraphic outline |
1 |
Select an object.
2 |
3 |
In the Corners area, enable a corner style.
4 |
In the Calligraphy area, type a value in the Stretch box to change the width of the
pen’s nib.
The value range is from 1 to 100, with 100 as the default setting. Reducing the value makes square nibs rectangular and round nibs oval, creating a more pronounced calligraphic effect. |
5 |
Type a value in the Angle box to change the orientation of the pen in relation to the
drawing surface.
To reset Stretch and Angle values to their original values, click Default.
You can also adjust the Stretch and Angle values by dragging in the Nib
shape preview box.
| To set the line and outline properties for new objects |
1 |
Using the Pick tool, click on an empty space in the drawing window to deselect all
objects.
2 |
3 |
In the Outline pen dialog box, click OK to change the default outline properties
for new graphic objects only.
If you want to change the outline properties for text objects as well, enable the Artistic text and Paragraph text check boxes. |
4 |
Specify the settings you want.
