The JPEG 2000 (JP2) file format is a JPEG image with advanced compression and file data capabilities. JPEG 2000 standard files can store more descriptive file data (or metadata), such as dimensions, tone scale, color space, and intellectual property rights, than JPEG 2000 codestream files. Codestream files are optimized for network transmission since they resist bit errors that can cause data loss on low-bandwidth channels.
Not all Web browsers support JPEG 2000 formats. You may require a plug-in to view these files.
When you export the image to a JP2 file, you can choose to view download progression by resolution, quality, and position.
To import a JPEG 2000 file | ![]() |
1 |
Click File ![]() |
2 |
Locate the folder in which the file is stored.
3 |
Do one of the following:
(Windows 7 and Windows Vista) Choose JP2 - JPEG 2000 Bitmaps (*.jp2;
*.j2k) from the list box next to the File name box.
(Windows XP) Choose JP2 - JPEG 2000 Bitmaps from the Files of type list
box.
4 |
Click the filename.
5 |
Click Import.
6 |
Click the drawing page.
To export a JPEG 2000 bitmap | ![]() |
1 |
Click File ![]() |
2 |
Choose JP2 - JPEG 2000 bitmaps from the Save as type list box.
3 |
Type a name in the File name box.
4 |
Click Export.
5 |
Choose a JPEG 2000 preset from the Preset list list box in the upper-right corner
of the dialog box.
If you want modify the preset settings, you can change the exporting options in the dialog box. |
6 |
Click OK.
JPEG 2000 (JP2) technical notes | ![]() |
CorelDRAW can import either JP2 or JPC files but export only to the JP2 format.
CMYK, 48-bit RGB, and black-and-white images are not supported for export.
