Kodak Photo CD image file is a raster format developed by Eastman Kodak for scanning photographic images onto compact discs. PCD images are derived from 35-mm film negatives or slides that have been converted to digital format and stored on a CD. Photo CD allows high-quality digital storage and manipulation of photographic images. The PCD format is typically used by photofinishers and service bureaus who provide the service of placing photographs on CDs.
| To import a Kodak Photo CD image file |
1 |
Click File |
2 |
Choose the folder in which the file is stored.
3 |
Do one of the following:
(Windows 7 and Windows Vista) Choose PCD - Kodak Photo-CD image
(*.pcd) from the list box next to the File name box.
(Windows XP) Choose PCD - Kodak Photo-CD image from the Files of type
list box.
4 |
Click the filename.
5 |
Click Import.
6 |
In the PCD import dialog box, move any of the following sliders:
Brightness — lets you set the amount of light
Contrast — lets you specify the contrast between the pixels in the image
Saturation — lets you specify the purity of a color
Red — lets you specify the amount of red in the image
Green — lets you specify the amount of green in the image
Blue — lets you specify the amount of blue in the image
7 |
From the Resolutions list box, choose an image size.
8 |
From the Image type list box, choose a color mode.
9 |
Position the import placement start cursor on the drawing window, and click.
You can also
Resample a graphic while importing
For more information, see To resample a bitmap while importing.
Crop a graphic while importing
For more information, see To crop a bitmap while importing.
You can drag on the drawing page to resize the image.
You can remove the adjustments made by the photofinisher at the time the
original image was scanned and placed on the Photo CD disk by enabling the
Subtract scene balance check box.
You can identify out-of-gamut areas of the image by enabling the Show colors
out of gamut check box, which renders the out-of-gamut pixels in pure red or
pure blue.
| Kodak Photo CD Image (PCD) technical notes |
Kodak Photo CD (PCD) images may be subject to copyright. The Corel program
does not display a warning message about this.
Other Kodak-compatible programs may install the Kodak pcdlib.dll file in the
Windows folder instead of the Windows\System folder. This difference in the
folder location produces an error message.
When you import Photo CD files, a dialog box appears and prompts you to choose
the desired file resolution and color. The resolution is limited to 72 dpi and the
maximum image size is 3072 × 2048 pixels.
You can import the following color modes: RGB (24-bit), paletted (8-bit), and
grayscale (8-bit).
