After you have started a drawing with a template, you can load a different template. When you load a template, you can choose to load just the styles or to load styles, page layout settings, and objects.
| To load styles from another template |
1 |
Click Tools |
2 |
In the Graphic and text styles docker, click the flyout button |
3 |
Locate the folder where the template is stored.
4 |
Click the template that contains the styles that you want to load.
5 |
Click Open.
When you use the Load command, only the styles are loaded. CorelDRAW
does not use the page layout settings in the template and does not add to the
page any objects saved with the template. The attributes of existing objects are
maintained.
