Macromedia Flash is a file format for creating and displaying vector-based images and animation. Macromedia Flash files are extremely compact and of high quality, making them ideal for use on the Web.
Before you save a file to the Macromedia Flash file format, you can determine whether the file has potential export problems. You can check the current file and display a summary of errors, possible problems, and a suggestion for resolving the issue.
| To export a Macromedia Flash file |
1 |
Click File |
2 |
Locate the folder in which you want to save the file.
3 |
Choose SWF - Macromedia Flash from the Save as type list box.
4 |
Type a filename in the File name list box.
5 |
Click Export.
6 |
In the Flash export dialog box, choose values from any of the following list boxes:
JPG compression — specifies the amount of JPEG file compression
Resolution (dpi) — specifies the resolution of the image
Smoothing — tones down differences between adjacent pixels
7 |
Enable one of the following options in the Bounding box size area:
Page — applies the bounding box to the page
Objects — aligns the bounding box to the objects in the file
8 |
Enable any of the following check boxes in the Optimization area:
Convert dashed outlines — converts dashed outlines to solid lines
Rounded caps and corners — rounds the corners and endpoints of lines and
curves
Use default fountain steps — lets you use the default number of steps for
fountain fills
The more you compress a sound, the smaller the size and the lower the sound
quality.
You can save the settings in the Flash export dialog box to a preset by clicking
the Add preset button |
To preview a Macromedia Flash file in a browser, you must have the
Macromedia Flash Player plug-in installed on your computer.
| To view the issues summary for a Macromedia Flash file |
1 |
Click File |
2 |
3 |
4 |
5 |
Click Export.
6 |
In the Flash export dialog box, click the Issues tab.
7 |
Click an error or warning in the error list to see the details and suggestions for
If you want to overlook certain issues, click Settings, and disable the check boxes that correspond to those issues. |
The Issues tab heading indicates the number of issues. The icon on the tab
heading changes, depending on the severity of the issue or issues identified.
| Macromedia Flash (SWF) technical notes |
Macromedia Flash (SWF) files cannot be imported into CorelDRAW.
