When you create symbols, you can store them in library files that are grouped into collections. You can store symbols in a local library, so that they are only available in the current drawing, or you can export symbols to a network library that can be shared between drawings.
The Symbol manager docker always displays libraries and collections that are in your local Symbols folder. You can add collections and libraries to your Symbols folder from elsewhere on the network. When you insert a local or external symbol into a drawing, a copy of the symbol definition is added to the document, but it remains linked to the source symbol.
| To add a collection or library |
1 |
Click Window |
2 |
In the tree, click Local Symbols or Network Symbols.
3 |
Click the Add library button |
4 |
Locate and choose a collection or library.
5 |
Click OK.
By default, library files are referenced from their original location. If you want
to copy a library to your User Symbols folder, enable the Copy libraries
locally check box.
If you are adding a collection, you can enable the Recursive check box to
include subfolders.
| To delete a collection or library |
1 |
In the Symbol manager docker, click a collection or library.
2 |
Press Delete.
The collection or library is removed from the tree in the Symbol manager
docker, but files are not deleted.
