This type of bitmap file is designed for the OS/2 operating system. The OS/2 Bitmap file format supports a maximum image size of 64,535 × 64,535 pixels. OS/2 uses Run-length encoding (RLE) compression.
OS/2 Bitmap (BMP) technical notes | ![]() |
Corel programs support Standard Version 1.3 and Enhanced Version 2.0, or later
versions of the OS/2 Bitmap file format.
Corel programs support the following color depths when importing and exporting
BMP files: 1-bit black and white, 256 shade (8-bit) grayscale, 16-color (4-bit) and
256-color (8-bit) paletted, and 24-bit RGB.
