The PaintBrush (PCX) file format is a bitmap format originally developed by the ZSoft Corporation for the PC Paintbrush program.
To import a PaintBrush file | ![]() |
1 |
Click File ![]() |
2 |
Locate the folder in which the file is stored.
3 |
Do one of the following:
(Windows 7 and Windows Vista) Choose PCX - PaintBrush (*.pcx) from the
list box next to the File name box.
(Windows XP) Choose PCX - PaintBrush from the Files of type list box.
4 |
Click the filename.
5 |
Click Import.
6 |
Click the drawing page.
To export a PaintBrush file | ![]() |
1 |
Click File ![]() |
2 |
Locate the folder in which you want to save the file.
3 |
Choose PCX - PaintBrush from the Save as type list box.
4 |
Type a filename in the File name list box.
5 |
Click Export.
6 |
In the Convert to bitmap dialog box, adjust the width, height, resolution, color
mode, or any of the other settings.
PaintBrush (PCX) technical notes | ![]() |
Bitmaps may be black-and-white, 16 colors, grayscale (8-bit), paletted (8-bit), or
RGB color (24-bit).
Run-length encoding (RLE) compression is supported, and the maximum image
size is 64,535 × 64,535 pixels.
These files may contain one, two, or four color planes.
This file format is supported in CorelDRAW and Corel PHOTO-PAINT.
PCX files can be imported if they conform to the following PCX specifications: 2.5,
2.8, and 3.0.
RGB color (24-bit).
RLE compression is supported and the maximum image size is 64,535 × 64,535
pixels.
These files may contain one, two, or four color planes. Files containing three color
planes or more than four color planes cannot be imported.
