By default, drawings are saved to the CorelDRAW file format (CDR) and are compatible with the latest version of the application. You can also save a drawing that is compatible with an earlier version of CorelDRAW Graphics Suite.
You can save a drawing to other vector file formats as well. If you want to use a drawing in another application, you must save it to a file format that is supported by that application. For information about saving files to other formats, see Exporting files.
When you save a drawing, CorelDRAW lets you add reference information so that you can easily find and organize drawings later on. On Windows 7 and Windows Vista, you can attach tags (also known as properties) such as title, subject, and rating. On Windows XP, you can assign notes and keywords to a drawing.
If your drawing will be viewed on a system that does not have all of the fonts used in the drawing, you can embed all fonts to ensure that text will appear as originally created.
You can also save selected objects in a drawing. For large drawings, saving only the selected objects reduces the file size, which can decrease the time it takes to load the drawing.
When saving a file, you can use advanced options to control how bitmaps, textures, and vector effects, such as blends and extrusions, are saved with the drawing.
You can also save a drawing as a template, which lets you create other drawings with the same properties. For information about saving a drawing as a template, see Working with templates.
| To save a drawing |
1 |
Click File |
2 |
Type a filename in the File name list box.
3 |
Locate the folder where you want to save the file.
If you want the drawing to be compatible with a previous version of CorelDRAW, choose a version from the Version list box. |
If you want to save the drawing to a vector file format other than CorelDRAW (CDR), choose a file format from the Save as type list box. |
If you are using an expired trial version of CorelDRAW, you will not be able
to save drawings.
For more information about trial versions, see Working with trial versions.
Saving a drawing to a previous version of CorelDRAW may result in loss of
certain effects that were not available in the previous version of the application.
When you save to a previous version of CorelDRAW, the content and
appearance of the document is maintained, but layers are affected in the
following ways:
Layer names are reset to CorelDRAW default names.
The number of layers per page is set according to the page with the
most layers.
Master layers are converted to local layers, with the exception of the
default master layers (Guides, Grid, Desktop).
Local Guides layers are converted to regular layers.
For more information about layers, see Working with layers.
You can also save a drawing by clicking File |
You can also save a drawing by clicking the Save button |
| To use advanced options when saving |
1 |
Click File |
2 |
Click Advanced.
3 |
Enable any of the following check boxes:
Save presentation exchange — saves a drawing as a Corel Presentation
Exchange (CMX) file so that you can open and edit it in other Corel applications,
such as WordPerfect
Use bitmap compression — reduces the file size by compressing bitmap
effects, such as bitmap extrusions, transparencies, and drop shadows
Use graphic object compression — reduces the file size by compressing vector
objects, such as polygons, rectangles, ellipses, and perfect shapes
Using compression increases the time required for opening and saving a drawing. |
4 |
If a drawing contains texture fills, enable one of the following options:
Save textures with the file — saves custom texture fills with the file
Rebuild textures when opening a file — re-creates texture fills when you open
the saved drawing
5 |
If a drawing contains blends and extrusions, enable one of the following options:
Save blends and extrudes with the file — saves all blends and extrusions
included in a drawing
Rebuild blends and extrudes when opening the file — re-creates blends and
extrusion when you open the saved drawing
Choosing to save textures, blends, and extrusions with the file increases the file
size but lets you open and save a drawing more quickly. Conversely, choosing
to rebuild textures, blends, and extrusions when a saved drawing is opened
decreases the file size but increases the time required for saving or opening a
drawing.
