CorelDRAW lets you size and scale objects. In both cases, you change the dimensions of an object proportionally by preserving its aspect ratio. You can change the dimensions of an object by specifying values or by changing the object directly. When you scale an object, you change its dimensions by a specified percentage.
You can change the anchor point of an object from its center to any of its eight selection handles.
| To size an object |
You can also set a precise size for the object by typing values in the Object size
boxes on the property bar.
You can also size an object by clicking Arrange |
| To scale an object |
1 |
Select an object.
2 |
Do one of the following:
In the toolbox, click the Free transform tool |
Click Window |
3 |
Click the Free scale button |
4 |
Type a percentage by which you want to scale the object in the Scale factor boxes
You can also scale an object by dragging a corner selection handle.
