In-RIP trapping allows you to specify advanced trapping settings. Before selecting In-RIP trapping, ensure that your PostScript 3 printer supports In-RIP trapping options.
You can select a trap width — the amount that one color spreads into another. You can also specify image trap placement, which determines where the trap occurs. You can, for example, specify whether the trap is a choke or a spread, depending upon the neutral densities of adjacent colors. Neutral density indicates the lightness or darkness of a color and helps determine how adjacent colors spread into one another.
You can specify a threshold at which a trap is created by specifying a step trap limit. If trap colors are of similar neutral densities, the trap placement adjusts accordingly. The step trap limit specifies a threshold at which a trap adjusts.
Before trapping, you can set the inks; for example, you can set an ink to opaque, as in the case of a metallic ink, so that nothing shows through it. To reduce the visibility of a trap, you can decrease the amount of ink color in a trap. This is especially helpful in the case of pastel colors, contrasting colors, and colors with similar neutral densities.
| To select a trap width |
1 |
Click File |
2 |
Click the Color tab.
3 |
Enable the Print composite option.
4 |
Click the PostScript tab.
5 |
Choose PostScript 3 from the Compatibility list box.
6 |
Click the Composite tab.
7 |
Enable the PostScript 3 In-RIP trapping check box.
8 |
Click Settings.
9 |
Type a value in the Trap width box.
If you are trapping to black, type a value in the Black trap width box. |
To select In-RIP trapping options, you must have selected PostScript 3 from
the Compatibility list box under the PostScript tab of the Print dialog box.
| To specify image trap placement |
1 |
Click File |
2 |
3 |
4 |
5 |
6 |
7 |
Enable the PostScript Level 3 in-RIP trapping check box.
8 |
Click Settings.
9 |
From the Image trap placement list box, choose one of the following placements:
Neutral density — used to determine the lighter object and thus, the direction
and placement of the trap
Choke — used to trap a dark foreground object to a light background image
Spread — used to trap a light foreground object to a dark background image
Centerline — used when adjacent images and objects have similar neutral
densities or when image density changes along an object’s edge
If you want to trap an object to an image, enable the Trap objects to images option. |
| To specify a threshold |
1 |
Click File |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
Click Settings.
9 |
Type a value in one or any of the following boxes:
Step limit — specifies a threshold between color variations. The lower the
threshold value, the more likely it is that a trap will be created.
Black limit — specifies the threshold at which process black is considered pure
black
Black density limit — specifies a neutral density value for the black ink
Sliding trap limit — specifies the difference between the neutral densities of
adjacent colors at which a trap adjusts (slides) from the darker side of a color edge
toward the centerline. The lower the sliding trap limit, the more gradual the
transition.
the Compatibility list box under the PostScript tab in the Print dialog box.
| To set inks for trapping |
1 |
Click File |
2 |
3 |
4 |
5 |
6 |
Click Settings.
7 |
In the Type column, select one of the following for each color separation:
Transparent — the selected ink doesn’t get trapped, but anything beneath it
does
Neutral density — the neutral density of the selected ink determines how it is
treated
Opaque — the selected ink is treated as opaque
Opaque ignore — the selected ink doesn’t get trapped nor does anything
beneath it
| To select a trap color reduction |
1 |
Click File |
2 |
3 |
4 |
5 |
6 |
Click Settings.
7 |
Type a value in the Trap color reduction box.
A reduction value of 100% indicates no reduction, while a lower value reduces
the neutral density.
