The TARGA(TGA) graphics format is used for describing bitmaps. It supports various compression systems and can represent bitmaps ranging from black-and-white to RGB color. You can import or export TGA files in CorelDRAW.
For more information about importing files, see Importing files.
To export a TARGA file | ![]() |
1 |
Click File ![]() |
2 |
Locate the folder in which you want to save the file.
3 |
Choose TGA - Targa bitmap from the Save as type list box.
4 |
Type a filename in the File name list box.
To compress an image while exporting it, choose a compression type from the Compression type list box. |
5 |
Click Export.
6 |
In the Convert to bitmap dialog box, adjust the width, height, resolution, color
mode, or any of the other settings, and click OK.
7 |
In the TGA export dialog box, enable one of the following options:
Normal
Enhanced
Black-and-white images cannot be saved as TARGA files.
TARGA (TGA) technical notes | ![]() |
The following features are supported: uncompressed color-mapped images,
uncompressed RGB images, run-length encoding (RLE) compressed color-mapped
images, RLE-compressed RGB images (types 1, 2, 9, and 10 as defined by the
AT&T Electronic Photography and Imaging Center), and masks.
The type of file produced depends on the number of colors exported. For example,
24-bit color TARGA (TGA) files are exported as RLE-compressed RGB bitmaps.
You can import TGA files from 8-bit grayscale to 24-bit RGB.
Masks are not saved in 1-bit black-and-white or 8-bit paletted files.
RLE compression is supported, and the maximum image size is 64,535 × 64,535
pixels.
