You can undo the actions you perform in a drawing, starting with the most recent action. If you don’t like the result of undoing an action, you can redo it. Reverting to the last saved version of a drawing also lets you remove one or more actions. Certain actions applied to objects, such as stretching, filling, moving, and rotating, can be repeated to create a stronger visual effect.
Customizing the Undo settings lets you increase or decrease the number of actions that you can undo or redo.
| To undo, redo, and repeat actions |
When you undo a series of actions in the Undo docker, all actions listed below
the action you choose are undone.
When you redo a series of actions in the Undo docker, the action you choose
and all preceding undone actions are redone.
You can repeat an action on another object or group of objects by selecting the
object or objects and clicking Edit |
You can also undo or redo a series of actions by clicking the arrow button next
to the Undo button |
| To specify the Undo settings |
1 |
Click Tools |
2 |
In the Workspace list of categories, click General.
3 |
Type a value in one or both of the following boxes:
Regular — specifies the number of actions that can be reversed when you use
the Undo command with vector objects
Bitmap effects — specifies the number of actions that can be reversed when you
work with bitmap effects
The value that you specify is limited only by your computer’s memory
resources. The higher the value you specify, the greater the demand on memory
resources.
