There are a number of tasks that are common to all types of fills. You can choose a default fill color so that every object you add to a drawing has the same fill. You can also remove any fill, copy it to another object, or use it to fill an area surrounded by an open curve.
| To choose a default fill color |
1 |
Click a blank area on the drawing page to deselect all objects.
2 |
In the toolbox, click the Uniform fill tool |
3 |
In the Uniform fill dialog box, enable any of the following check boxes:
Graphic — applies the default fill color to shapes you draw
Artistic text — applies the default fill color to artistic text you add
Paragraph text — applies the default fill color to paragraph text you add
4 |
Specify any fill settings.
| To remove a fill |
1 |
Select an object.
2 |
In the toolbox, click the Fill flyout, and click the No Fill button |
| To copy a fill to another object |
1 |
Using the Pick tool |
2 |
Right-click the first object, and then drag over the destination object, to which you
want to apply the fill.
A blue outline of the first object follows the pointer to the destination object. |
3 |
When the pointer changes to a crosshair pointer |
You can also use the Attributes eyedropper |
You can also sample the color of an existing object and apply the sampled color
to another object as a uniform fill. For more information, see To sample a color.
| To show fills in open curves |
1 |
Click Tools |
2 |
In the list of categories, double-click Document, and click General.
3 |
Enable the Fill open curves check box.
