You can load photos from digital cameras and scan images in CorelDRAW.
The 32-bit version of CorelDRAW supports scanners that use Microsoft Windows Image Acquisition (WIA), which provides a standard interface for loading images. If your scanner or digital camera does not support WIA, you can use the TWAIN driver of your scanner or digital camera for loading images. TWAIN is supported by both the 32-bit and 64-bit versions of CorelDRAW. The software interfaces and options vary. For information about using the software associated with your scanner or digital camera, see the manufacturer’s documentation.
| To load photos from a digital camera |
1. |
Connect a digital camera to your computer.
2. |
Click File |
3. |
Choose a digital camera from the Sources box.
4. |
Click File |
5. |
Choose the images you want to load from the dialog box that appears.
If your digital camera does not support WIA, you are presented with the digital camera’s TWAIN driver interface for loading images. Options vary, depending on the digital camera. |
6. |
Click Get pictures.
On your digital camera’s interface, this button may have a different name. |
To load additional photos during the same session, click File |
If your digital camera does not support WIA and does not have a TWAIN
driver, you can still open photos in CorelDRAW by clicking File |
| To scan images |
1. |
Click File |
2. |
Choose a scanner from the Sources list.
A scanner may have both a WIA and a TWAIN driver source. If you are scanning 48-bit color images, you must select the TWAIN driver. |
3. |
Click Select.
4. |
Click File |
If your scanner does not support WIA, you are presented with the scanner’s TWAIN driver interface for loading images. Options vary, depending on the scanner. |
5. |
Preview the image, and select the area that you want to scan.
6. |
Click Scan.
On your scanner’s interface, this button may have a different name, such as OK or Send. |
The WIA interface is available only for the Windows XP operating system.
To scan additional images during the same session, click File |
