Aligning text
CorelDRAW lets you align text in various ways. You can align paragraph text horizontally and vertically in relation to its text frame. You can align paragraph text with the baseline grid. For more information, see Aligning text by using the baseline grid. You can also align text to a selected object.
You can align a text object with other objects by using the baseline of the first line, the baseline of the last line, or the edge of the text frame.
Artistic text can be aligned horizontally, but not vertically. When you align artistic text, the entire text object is aligned in relation to the bounding box. If characters have not been shifted horizontally, applying no alignment produces the same result as applying left alignment.
Artistic text is aligned within the bounding box, which is indicated by eight selection handles (black squares). The text at the top is left-aligned; the text at the bottom is right-aligned.
To align text horizontally Back to Top
1.
Do one of the following:
Using the Text tool , select the text that you want to align.
Using the Pick tool , click an artistic text object or a text frame whose content you want to align.
If the Object properties docker is not open, click Window Dockers Object properties.
2.
In the Object properties docker, click the Paragraph button to display the paragraph-related options.
3.
In the Paragraph area of the Object properties docker, click one of the following buttons:
None — applies the default alignment setting
Align left — aligns text with the left side of the text frame or the bounding box of artistic text
Center — centers text within the text frame
Align right — aligns text with the right side of the text frame and the bounding box of artistic text
Full justify — aligns text, with the exception of the last line, with the left and right sides of the text frame
Force justify — aligns text, including the last line, with the left and right sides of the text frame
You can also align text horizontally by clicking the Horizontal alignment button on the property bar and choosing an alignment style from the list box. The property bar displays an icon that corresponds to the current alignment style.
You can align multiple paragraphs in a text frame by selecting them with the Text tool and choosing an alignment style.
To align paragraph text vertically Back to Top
1.
Using the Pick tool , click a text frame.
2.
In the Object properties docker, click the Frame button to display the frame- related options.
3.
In the Frame area of the Object properties docker, choose an alignment option from the Vertical alignment list box.
To align text with an object Back to Top
1.
Using the Pick tool , hold down Shift, click the text object, and then click the object.
2.
Click Arrange Align and distribute Align and distribute.
3.
Choose one of the following from the For text source objects use list box:
First line baseline — uses the baseline of the first line of text to align the objects
Last line baseline — uses the baseline of the last line of text to align the objects
Bounding box — aligns text with its bounding box
4.
Enable one of the following horizontal alignment check boxes:
Left
Right
Center
5.
Enable one of the following vertical alignment check boxes:
Top
Bottom
Center
6.
Click Apply.
If you select the text objects one at a time, the last object selected is the reference point for aligning the other objects. If you marquee select the objects before you align them, the object that is positioned in the upper-left corner of the selection is used.
If you have applied a linear transformation, such as rotation, to the text and are aligning objects with a baseline, the objects align with the baseline point of the starting edge of the text object.
You can also align text objects by selecting them and clicking the Align and distribute button on the property bar.
