Applying perspective to objects
You can create a perspective effect by shortening one or two sides of an object. This effect gives an object the appearance of receding in one or two directions, thereby creating a one-point perspective or a two-point perspective.
Perspective effects can be added to objects or grouped objects. You can also add a perspective effect to linked groups, such as contours, blends, and extrusions. You can’t add perspective effects to paragraph text, bitmaps, or symbols.
The original graphic (left) with one-point (middle) and two-point (right) perspectives applied to it.
After you apply a perspective effect, you can copy it to other objects in a drawing, adjust it, or remove it from the object.
To apply a perspective Back to Top
To
Apply a one-point perspective
Click Effects Add perspective. Press Ctrl, and drag a node.
Apply a two-point perspective
Click Effects Add perspective. Drag the nodes on the outside of the grid to apply the effect you want.
Pressing Ctrl constrains the node’s movement to the horizontal or vertical axis to create a one-point perspective effect.
You can move opposing nodes the same distance in opposite directions by pressing Ctrl + Shift as you drag.
To copy an object’s perspective effect Back to Top
1.
Select an object to which you want to apply a perspective effect.
2.
Click Effects Copy effect Perspective from.
3.
Select an object whose perspective effect you want to copy.
You can also use the Attributes eyedropper tool to copy a perspective effect. For more information, see To copy effects from one object to another.
To adjust the perspective Back to Top
1.
In the toolbox, click the Shape tool
2.
Select an object that has a perspective effect.
3.
Drag a node to a new position.
You can also adjust the perspective by dragging one or both of the vanishing points.
To remove a perspective effect from an object Back to Top
1.
2.
Click Effects Clear perspective.
