A print style is a set of saved printing options. Each print style is a separate file. This lets you move a print style from one computer to another, back up a print style, and keep document-specific styles in the same directory as the document file.
You can select an existing print style, create a new print style, or edit a print style and save the changes. You can also delete print styles.
| To choose a print style |
1. |
Click File |
2. |
Click the General tab.
3. |
Choose one of the following from the Print style list box:
CorelDRAW defaults
Browse
| To create a print style |
1. |
Click File |
2. |
3. |
Set any printing options.
4. |
Click Save as.
5. |
Choose the folder where you want to save the print style.
6. |
Type a name for the style in the Filename box.
You can also save a print style by clicking File |
| To edit a print style |
1. |
Click File |
2. |
Choose a print style from the Print style list box.
3. |
Modify any of the printing options.
4. |
Click Save as.
5. |
Choose the folder where the print style is stored.
6. |
Click the filename.
7. |
Click Save.
You should save the modified settings as a print style or apply the changes
before canceling; otherwise, you’ll lose all the modified settings.
| To delete a print style |
1. |
Click File |
2. |
Select a print style.
3. |
Click the Delete print style button
