You can apply a wide range of special effects to bitmaps, such as three-dimensional (3D) and artistic effects.
Adding plug-in filters to CorelDRAW provides additional features and effects that you can use to edit images. You can add plug-in filters, and you can remove them when you no longer need them.
Left to right: Add noise effect, Zoom blur effect, Solarize color transform effect, Edge detect contour effect, Sharpen effect
Left to right: Original image, Emboss effect, Cubist artistic effect, Mosaic creative effect, Distort pixelate effect
CorelDRAW automatically inflates a bitmap so that a special effect covers the entire image. You can disable automatic inflation and manually specify dimensions for the inflated bitmap.
| To apply a special effect |
1. |
Select a bitmap.
2. |
Click Bitmaps, choose a special effect type, and click an effect.
3. |
Adjust any special effect settings.
| To add a plug-in filter |
1. |
Click Tools |
2. |
In the list of categories, double-click Workspace, and click Plug-ins.
3. |
Click Add.
4. |
Choose a folder containing a plug-in.
To remove a plug-in filter, click a plug-in folder from the Plug-in folders list,
and click Remove.
| To inflate a bitmap manually |
1. |
Select a bitmap.
2. |
Click Bitmaps |
3. |
In the Width and Height areas, do one of the following:
In the Inflate to boxes, type the number of pixels that should make up the
dimensions of the inflated bitmap.
In the Inflate by boxes, type the percentages by which to inflate the original
bitmap.
4. |
To inflate the bitmap proportionally, enable the Maintain aspect ratio check box.
To automatically inflate the bitmap to cover the entire image, click Bitmaps
