Specifying a viewing option for EPS files
EPS files are PostScript files that are embedded in a document. You can choose how encapsulated PostScript (EPS) files are viewed in a PDF document. The PostScript option includes high-resolution images in the PDF document but does not let you view them in Adobe Acrobat. The Preview option includes high-resolution images in the PDF file and displays their low-resolution bitmap representation in Adobe Acrobat.
To choose a viewing option for EPS files Back to Top
1.
Click File Export.
2.
Choose PDF - Adobe Portable Document Format from the Save as type list box.
3.
Locate the folder in which you want to save the file.
4.
Type a filename in the File name box.
5.
Click Export.
The PDF settings dialog box appears.
6.
Click the Objects tab.
7.
Choose one of the following from the EPS files list box:
PostScript — includes high-resolution images in the PDF document but does not let you view them
Preview — includes high-resolution images in the PDF file and displays their low-resolution bitmap representation
