Arrowheads let you enhance the starting points and endpoints of lines and curves. You can specify the attributes of an arrowhead with precision. For example, you can define the exact size of an arrowhead as well as offset or rotate the arrowhead by a precise amount. You can also flip arrowheads vertically and horizontally. You can save your specified attributes as arrowhead presets for later use.
Arrowhead in its original form (1), resized (2), with offset of 60% along the x-axis (3), flipped horizontally (4), and rotated at 90 degrees (5).
You can edit existing arrowhead presets, and you can create an arrowhead preset based on an existing one. You can also create an arrowhead preset based on an object such as a curve or a closed shape. When you no longer need an arrowhead preset, you can delete it.
| To add an arrowhead |
1. |
Select a line or curve.
2. |
Open the Start arrowhead picker on the property bar, and click a line-ending
shape.
3. |
Open the End arrowhead picker, and click a line-ending shape.
You can remove an arrowhead by choosing the No arrowhead preset from the
Start arrowhead or End arrowhead picker.
You can also add arrowheads from the Outline pen dialog box or the Outline
section of the Object properties docker.
| To specify the arrowhead attributes of a line or curve |
1. |
Using the Pick tool
2. |
Click Window |
3. |
In the Outline section, click the Arrowhead settings button
If the Outline section is not displayed, click Outline. If the Arrowhead settings button is not displayed, click the arrow at the bottom of the Outline section. |
If you want starting and ending arrowheads to have the same size, offset, rotation angle, and orientation, enable the Share attributes check box. |
4. |
In the Arrowhead attributes dialog box, perform any of the tasks in the following
table.
You can switch arrowheads from one end of a line or curve to another by
clicking the Arrowhead settings button, and clicking Swap.
You can remove an arrowhead from a line or curve by clicking the Arrowhead
settings button, and clicking None.
| To edit an arrowhead preset |
1. |
Using the Pick tool
2. |
Click Window |
3. |
In the Outline section, click the Arrowhead settings button next to the Start
arrowhead picker or the End arrowhead picker, and click Edit.
If the Outline section is not displayed, click Outline. If the Start arrowhead picker is not displayed, click the arrow at the bottom of the Outline section. |
4. |
In the Arrowhead attributes dialog box, specify the attributes you want.
You can create an arrowhead preset that is based on an existing preset. Click
Arrowhead settings button, and click New. Then, specify the attributes you
want in the Arrowhead attributes dialog box, and type a preset name in the
Save arrowhead area.
To delete an arrowhead preset, select the preset from the Start or End
arrowhead picker, click the Arrowhead settings button, and click Delete.
| To create an arrowhead preset from an object |
1. |
Select an object to use as an arrowhead.
2. |
Click Tools |
3. |
In the Create arrowhead dialog box, type a value in the Length box or Width
box.
If you want to create a nonproportional arrowhead, disable the Proportional check box, and type values in both the Length and Width boxes. |
