Corel Painter (RIF)
Imported Corel Painter (RIF) files retain information such as floating objects, which makes the files much larger than GIF or JPEG files. Corel Painter files can be imported for resizing and adjusting floaters.
To import a Corel Painter file Back to Top
1.
Click File Import.
2.
Locate the folder in which the file is stored.
3.
Do one of the following:
(Windows 7 and Windows Vista) Choose RIFF - Painter (*.rif) from the list box next to the File name box.
(Windows XP) Choose RIFF - Painter from the Files of type list box.
4.
Click the filename.
5.
Click Import.
6.
Click the drawing page.
You can also
Resample a graphic while importing
For more information, see “To resample a graphic while importing.”
Crop a graphic while importing
For more information, see “To crop a graphic while importing.”
Corel Painter (RIF) technical notes Back to Top
The embedded color profile is preserved, but can be changed after importing the file.
If the Corel Painter image contains a transparent background, which is called a canvas in Corel Painter, it is preserved.
Vector shapes are not preserved in the imported file.
Text and annotations are not preserved.
Bitmap layers are imported as grouped objects.
Liquid Ink, Watercolor, Digital Watercolor, and plug-in layers are imported as RGB objects.
Mosaics and tesselations are imported as RGB objects.
Image slicing is not retained.
