Custom color palettes are collections of colors or color styles that you save. They can include colors or color styles from any color model, including spot colors, or color palette found in the Palette libraries. You can create a custom palette to store all of the colors or color styles that you need in a current, or future, project.
This makes it easy for you to share the color palettes with others. The custom palettes are accessible from the My palettes folder in the Color Palette Manager.
You can create a custom color palette by choosing individual colors or color styles, or by using the colors in a selected object or an entire document. You can also edit, rename, and delete custom color palettes.
Custom color palettes are saved as .XML files and are stored in the My Documents\My Palettes folder.
To create a custom color palette from scratch | ![]() |
1. |
Click Window ![]() ![]() |
2. |
Click the Creates a new empty color palette
3. |
Type a filename in the File name box.
4. |
Click Save.
5. |
In the Color palette manager, choose the custom palette that you created.
6. |
Click the Opens the Palette editor
7. |
In the Palette editor dialog box, click Add color.
8. |
In the Select color dialog box, choose a color, and click Add to palette.
To add a color to a custom color palette | ![]() |
1. |
Open a custom color palette.
2. |
Perform a task from the following table.
When dragging most vector objects, all object colors are added to the palette.
When dragging a bitmap, you can specify the number of colors that you want
to be added to the palette. If an object includes a fountain fill, texture fill, or
pattern fill, only colors that are defined during the fill creation are supported.
Colors from PostScript fills are not supported.
To create a color palette from an object | ![]() |
1. |
Select an object.
2. |
3. |
4. |
Click Save.
To create a color palette from a document | ![]() |
1. |
2. |
3. |
Click Save.
To edit a custom color palette | ![]() |
1. |
2. |
Choose a palette from the list box.
3. |
You can delete multiple colors by holding down Shift or Ctrl, clicking the
colors that you want to delete, and clicking Delete color.
If you add a process color to the palette, but treat it as a spot color, the color is
changed to spot and the color name is preserved. However, if you choose a spot
color with a trademarked name, for example a PANTONE color, and convert
it to a process color, the trademarked name is substituted with the color
components for that color.
To rename a custom color palette | ![]() |
1. |
2. |
From the My Palettes folder, right-click a custom palette, and click Rename.
3. |
Type a new name, and press Enter.
To delete a custom color palette | ![]() |
1. |
2. |
From the My Palettes folder, right-click a custom palette, and click Delete.
