You can customize toolbar position and display. For example, you can move or resize a toolbar, and you can choose to hide or display a toolbar.
Toolbars can be either docked or floating. Docking a toolbar attaches it to the edge of the application window. Undocking a toolbar pulls it away from the edge of the application window, so it floats and can be easily moved around.
You can create, delete, and rename custom toolbars. You can customize toolbars by adding, removing, and arranging toolbar items. You can adjust toolbar appearance by resizing buttons; adjusting the toolbar border; and displaying images, captions, or both. You can also edit toolbar button images.
When moving, docking, and undocking toolbars, you use the grab area of the toolbar.
If you do not want to move docked toolbars by mistake, you can lock them. Locked toolbars do not have a dotted line along their left edge.
A locked toolbar
| To customize toolbar position and display |
Docked toolbars cannot be moved when they are locked. For information
about unlocking toolbars, see To lock or unlock toolbars.
| To add, delete, or rename a custom toolbar |
| To add or remove an item on a toolbar |
1. |
Click Tools |
2. |
In the Customization list of categories, click Commands.
3. |
Choose a command category from the top list box.
4. |
Drag a toolbar item from the list to a toolbar in the application window.
If you want to remove an item from a toolbar, drag the toolbar item off the toolbar. |
| To arrange toolbar items |
1. |
Click Tools |
2. |
3. |
On the toolbar in the application window, drag the toolbar item to a new position.
If you want to move a toolbar item to another toolbar, drag the toolbar item icon from one toolbar to the other. |
You can copy a toolbar item to another toolbar by holding down Ctrl while
dragging a toolbar item.
| To modify toolbar appearance |
1. |
Click Tools |
2. |
In the Customization list of categories, click Command bars.
3. |
Click a toolbar name in the list.
If you want to choose multiple toolbars, hold down Ctrl, and click the other toolbar names. |
4. |
Choose a size from the Button list box.
5. |
In the Border box, click an arrow to specify a value from 1 to 10 pixels for the
toolbar border.
6. |
From the Default button appearance list box, choose one of the following:
Caption below image
Caption only
Caption to right of image
Default
Image only
If you want to hide the title when the toolbar is floating, disable the Show title when toolbar is floating check box. |
You can reset a built-in toolbar to its default settings by clicking Reset.
| To edit a toolbar button image |
1. |
Click Tools |
2. |
3. |
4. |
Click a toolbar command.
5. |
Click the Appearance tab.
6. |
Edit the button image using the options in the Image area.
When you choose either Small or Medium in the Size list box, you edit the
small or medium versions of a particular button image. You cannot edit the
large version of a button image. For information about how to display all
buttons as small, medium, or large, see To modify toolbar appearance.
You can reset toolbar button images to the default settings by clicking Restore
defaults.
| To lock or unlock toolbars |
Click Windows |
The Lock toolbars command is enabled when a check mark appears beside it. When you launch the application for the first time, the toolbars are locked by default. |
Floating toolbars cannot be locked.
You can also lock or unlock toolbars by right-clicking a toolbar and clicking
Lock toolbars.
