Exporting and importing style sheets
You can make styles and style sets available for use in other documents by exporting them to a CorelDRAW style sheet (.cdss) file. A style sheet contains all the object styles, style sets, color styles, and default object properties in the active document. You can also use styles and style sets from other documents by importing the style sheet to which they were saved.
To export a style sheet Back to Top
1.
Click Tools Object styles.
2.
In the Object styles docker, click the Import, export, or save defaults button, and click Export style sheet.
3.
In the Export style sheet dialog box, choose the folder where you want to save the style sheet.
4.
Type a file name in the File name box.
5.
Click Export.
6.
Enable the check boxes for the settings you’d like to export from the document.
To import a style sheet Back to Top
1.
2.
In the Object styles docker, click the Import, export, or save defaults button, and click Import style sheet.
3.
In the Import style sheet dialog box, choose the folder where the style sheet is stored.
4.
Select the file name, and click Import.
5.
Enable the check boxes for the settings you’d like to import into the document.
You can also import styles and style sets from an existing CorelDRAW file by selecting the file in the Import style sheet dialog box and clicking the Import button.
