CorelDRAW lets you export palette-based bitmaps, such as paletted GIF or 8-bit PNG, with transparent colors and backgrounds. These bitmaps can contain objects, such as buttons and logos, which are commonly used on Web pages with colored or patterned backgrounds.
If you place an object with an opaque background onto a Web page, the object background color appears as a rectangle on the page. By making an object background transparent, the object background blends in with the page. Transparent object backgrounds also let you change the color or pattern of a Web page background without having to change the backgrounds of the objects to match.
You can create a GIF with a transparent background to use on a Web page.
| To save a bitmap with a transparent background |
1. |
From the Export for Web dialog box, choose a paletted file format, such as GIF or
8-bit PNG, from the Format list box.
2. |
Perform one or more tasks from the following table.
For best results, choose None from the Dithering list box in the Settings area.
